Need Shop in Portland Maine
Old Oct 19, 2020 | 08:14 AM
disco96sd's Avatar
Default Need Shop in Portland Maine
Anyone know a good shop in Portland Maine area ?
Thanks
Michael
Old Oct 19, 2020 | 04:43 PM
disco96sd's Avatar
Found Overland Engineering in Eliot - all is good - Thanks
Old Oct 21, 2020 | 12:12 PM
disco96sd's Avatar
Well well - really interesting what Overland Engineering found that left me stranded in Maine after a cross country trip - my Transfer Case was empty ! no obvious leaks - the transfer case oil was changed about 10k miles ago by well known LR independent shop in Santa Fe and I watched them do it - now looking at a swap out or rebuild - no obvious spots on my drive to tip me off - where did the oil go ? this is a 30K mile change item - I made 4 previous cross-country trips with no problem - strange
Old Oct 21, 2020 | 06:22 PM
Matt Browne is an awesome dude.
It has to be leaking somewhere unless they forgot to put the fluid back in
Old Oct 29, 2020 | 07:43 PM
disco96sd's Avatar
it appears that the breather hose on top of the transfer case slipped out of the holding bracket - it ended up being on the exhaust and melted shut - forcing the gear oil to spray out thru a gasket and coat the bottom of my Disco - thus no drips or leaks on the drive - and running it dry and causing it to break the bearing and finally seize the gears up - what a mess that was - I was saved by Matt Browne at Overland Engineering in the Portland ME area
d2rover
Engine & Internal
Mar 15, 2016 12:28 AM
Dirt Roamer
Aug 13, 2014 08:56 AM
GGhost
Dec 2, 2013 03:57 PM
ljdiscovery
Nov 1, 2009 04:40 PM
Doug
Dec 24, 2007 10:50 PM
