neutral safety switch or what?
Old Oct 12, 2011 | 02:52 PM
collin Barrows's Avatar
Originally Posted by antichrist
Those wouldn't cause slow cranking.
Colin, I highly recommend a starter from Britishstarters.com. It's a Denso gear reduction starter, better and cheaper than OE and has a lifetime warranty.
If you use enough extensions to have the ratchet/breaker bar just in front of the diff you don't need a wobble socket.
IIRC it's an 8mm Allen socket.
unfortunately it looks like they dont make starters for land rover.
Old Oct 12, 2011 | 02:55 PM
Originally Posted by Danny Lee 97 Disco
Another, albeit unconventional way to gain access to your starter for removal is to remove the front passenger tire. Looking into the wheel well, the starter is directly behind that inner fender wall.
I took a pair of aviation tin snips and very carefully cut the inner fender wall vertically upward right by the seam at the rear of the fender wall. That allowed me to basically fold the inner wall up and out of the way for clear unobstructed view and direct access to the starter and the 8mm allen cap screw that they are referring to.
Upon completion, the fender wall folds right back down into place. This also provides direct access to the exhaust/y-pipe junction to change that gasket.
I realize some people would never consider doing this to their Land Rover. In my opinion the improved access justifies doing it. Just wanted to let you know. Decide for yourself. I like to be able to see and reach what I am trying to work on without all the contortions involved in doing it the other way.
Hmmm didn't think about cutting the inner fender, I need to swap out my street tires for my muds.
Any recommended brands of starters?
Old Oct 12, 2011 | 03:15 PM
Might also check with local indy starter/alternator shop on replacing the solenoid, etc. I happened upon a rebuilt one at the salvage yard, and it cranks mine promptly.
Old Oct 12, 2011 | 06:33 PM
antichrist's Avatar
They do, I have one. Click the Land Rover logo on the home page.
willieg
Jan 31, 2015 04:37 AM
guyrumohr
Aug 6, 2014 04:42 PM
guyrumohr
Aug 6, 2014 04:34 PM
yogacwgrl
Oct 16, 2013 08:39 AM
discoboy
Nov 8, 2011 03:16 AM
