New bat+alt speedometer bouncing
^ Roger that, there is a male terminal on my starter with nothing attached. The rave calls it a 'Lucar'. I'm not sure if something fell off or it's some accessory that's not applicable to my model.
I think it's under
Electrical:
Service Repair no. 86.60.01
Image J6032
#8. Disconnect Lucar from solenoid.
I think it's under
Electrical:
Image J6032
on
Basically the first step in any significant effort is "Disconnect Battery Negative cable".
That prevents you from arc welding a wrench to the vehicle when you short a hot lead to the frame.
According to the RAVE instructions, removal of the starter is best done by a contortionist. According to my methyod, remove the front passenger's side wheel,
Stick your head under and you can see all of it.
There is supposed to be aheat shield over it, I removed mine years ago. I also took a pair of tin snips to that inner fender wall ner the sean and folded it out of the way and you are staring directly at the starter and the Y-pipe flange joint as well.
I completely reterminated my ground cable. Tom Rowe (AntiChrist )manufactures excellent replacement cables that are made with welding cable, milspec crimps and great insulation and even heat shielding.
Ok I scrubbed the starter with a wire brush and all seems well now, I appreciate everyone's help. I'll note that I used an entire can of degreaser on the underside in preparation for a suspension overhaul around last week. I left the engine alone for the cleaning. Maybe some got to the starter as I am missing the sheild. Food for thought. Again thank you everyone, I'm back in business.
Kyra96Disco112
10-31-2011 12:02 PM
alternator, battery, bosch, bouncing, broken, dead, discovery, flat, land, range, reading, rover, speedometer, sync, tachometer
