New d1 owner in eastern PA
Old 05-24-2013, 09:37 AM
tylor36's Avatar
Originally Posted by TOM R
one thing I would say is while it was apart you should have cleaned the rockers and pushrods etc to remove all that baked on oil sludge
I did but I don't have any picks of it
We made sure to clean everything we could. I also cleaned the valve covers and intakes and as much sludge as I could get off the side of the block and heads.
Old 05-24-2013, 02:57 PM
tylor36's Avatar
Does anyone know how I could tell if these steel wheels on my car are Defender "wolf" rims? I keep seeing them around, but can't see how I might be able to verify they are.
Old 05-26-2013, 05:13 PM
tylor36's Avatar
Update:
Today my dad and myself fixed the injector problem. Now no fuel leaks and it runs very smooth and starts right up. The only thing I noticed is the first time it heated up when I went down to get some gas is it didn't want to start after that. I just turned it over about 3 times and it fired right up.
I also pulled up the trunk carpet, and there was rust to be expected. I do not have any through holes but the pass. side near the back of the trunk is pretty much rotted through. I will get some pictures soon and post them up.
Old 05-26-2013, 08:03 PM
TOM R's Avatar
once you take a wire wheel to some of that rust you may have rust through, we did
Old 05-28-2013, 08:20 AM
tylor36's Avatar
Well took out the back seats and the carpet to take a look at the damage. It is not as bad as I was expecting. This is next weeks project to cut out the cancer and fix it up. I don't have a picture but the drivers side rocker panel is gone also.
Old 05-28-2013, 11:45 AM
TOM R's Avatar
wow, this is why I just ripped out the carpet padding and threw it away, it is just a sponge that traps moisture against the body and will never dry out, only down side is there will be an increase of road noise
Old 05-28-2013, 08:09 PM
tylor36's Avatar
Well when I get the rest of it apart I want to figure out where it leaks in, I am suspecting the back windows ( the seals are very dry rotted) but I am trying to find a cheaper place to get them. The other thing I can't seem to find is where to get door seals at a good price, all of mine are either flat as hell or rotted and falling apart.
Old 06-04-2013, 10:02 AM
tylor36's Avatar
So last saturday I took out the distilled water I put in after the Headgasket job and put in a mix of 50/50 w/ water wetter. I went to change the thermostat but I broke the lower bolt off trying to get it out. I let it alone for now and its not leaking, but that will have to be attended to.
I took yesterday off to work on some body work, but unfortunately I was beat from doing a tough mudder sunday afternoon so I didn't do much of anything.
Anyone have any suggestions on the course of action for the broken bolt? My dad has done a few drill outs before, but I don't think he has on aluminium.
Old 06-09-2013, 09:49 PM
tylor36's Avatar
Took out the rest of the interior to see the extent of the damage, boy my dad and I have our work cut out for us.
discovery restoration | Flickr - Photo Sharing!
Flickr will be my new home for a things disco pictures, I have a bunch of shots of the damage up there.
I was not feeling to bad about the boot floor, but then I ripped up the crappy waterlogged excuse for insulation under the drivers and passenger seat, boy was I shocked
danhawk
09-10-2014 07:40 AM
Roverrocks
12-10-2013 06:05 PM
acibarich
08-23-2013 01:33 PM
RCPro87
09-01-2010 05:45 PM
Markster
06-22-2008 08:42 AM
Quick Reply: New d1 owner in eastern PA
