New to discovery world
Old Jun 22, 2015 | 04:29 AM
Kyle DeBono's Avatar
Talking New to discovery world
Hi All, I just bought a 300tdi disco, I had a 300tdi defender back in 2010 / 2011 but sold it due to having a lot of mechanical problems. Anyway I now bought a discovery and don't really know anything about them.
Can anyone suggest some points that I should take care of (body and mechanical)? What are common problems on the disco and maybe some pointers to watch out from?
Thanks and pleased to meet you all
Old Jun 22, 2015 | 09:25 AM
TOM R's Avatar
No idea on the diesel engine but rest is things like service rears and swivels, service trans and t case, check drive shafts, clean grounds, put dielectric grease in any plug connectors to ward off corrosion
Old Jun 22, 2015 | 10:30 AM
WaltNYC's Avatar
Welcome to the board. It is very helpful for us to know what year/model truck you have. The info can be put in your signature using the "User CP" section of the message board. You can find "User CP" just above the "new reply" at the top of this thread.
Also doesn't hurt to put your location in there as well. You'd be surprised at the location specific help you might benefit from.
Old Jun 23, 2015 | 01:33 AM
loanrangie's Avatar
Timing belt change is critical although if fitted with the updated major kit the period can be extended from that of the manual ( 50-60K miles ), valve clearances are crucial to good performance and smooth running.
Frequent oil changes will help with longevity, otherwise driveline is the same as V8 models and similar to the defender.
They are prone to overheating and cracking heads so coolant hoses, t/stat and coolant would be on my priority list for servicing as well as having the radiator cleaned professionally.
Disco Fuego
Oct 20, 2009 05:29 PM
thumbsup
Sep 16, 2007 06:40 PM
ldjfsj
Feb 19, 2007 12:30 PM
JAYMONEY
May 16, 2006 12:29 AM
Loose_Screws
Jul 19, 2005 06:31 PM
