New lift, now, impossible to drive...
Old Mar 23, 2014 | 05:47 PM
CUpgt's Avatar
3 on 2" usually
Old Mar 23, 2014 | 08:07 PM
TOM R's Avatar
Don't think most need to castor correct the 2" remove the sway bars they make it worse with the lift on this vehicle
That full kit is the best deal if you want to do the whole suspension
What weight springs you get? Some are made to carry a certain weight gear all the time
Old Mar 24, 2014 | 12:30 AM
Kalev's Avatar
I bought the Medium Load Kit, should be used on vehicles carrying up to 220LB of equipment on front and up to 440LB equipment in the rear.
My original idea was to build the truck slowly, maybe that was a bad approach?
Old Mar 24, 2014 | 07:53 AM
CUpgt's Avatar
My truck rode fine on MD TF springs with no gear, bumpers, etc. I run HD RTE springs now with only a front bumper and rack and it also rides fine. I doubt that your problem.
Old Mar 24, 2014 | 07:55 AM
TOM R's Avatar
Here is an example my some springs require 150# ? Constant load on front or they give more lift then designed and a bad ride, I did the winch then lift, could be part of the problem but I am sure beat bushings are a large factor, I do not think you need cranked arms as you will set down once you add the weight
How are you not hitting front shaft on sway bar?
Old Mar 24, 2014 | 10:54 AM
Kalev's Avatar
Eventually I will add my winch and bumper... I just wish weekends were longer The truck drives the same as it did before the lift, so I'm sure its the worn bushings.
I actually found the TF253 Terrafirma Adjustable Panhard Rod, and I'm thinking that might be the way to go for now, then I can buy the bushing kit later to fix other issues as I find them.
I most definitely rub, but I'm not sure where, I ran out of time so I will have to check next weekend :\
Old Mar 24, 2014 | 11:10 AM
CUpgt's Avatar
Panhard bar is a case by case need on 2". It most certainly wont hurt and will take care of the bushings on it.
Old Mar 24, 2014 | 12:45 PM
fishEH's Avatar
Wait, what!? It drove the same BEFORE the lift? Then yeah, it's bushings or something.
You probably don't need a panhard but if you're going with an adjustable one I like that one a lot because it uses stock bushings on each end. Heims have no place on a truck driven on the road, IMO.
Old Mar 24, 2014 | 05:19 PM
MM3846's Avatar
meh, i prefer heims. they handle the extra weight/forces wheeling puts on them better than TREs and bushings.. just depends on how you're using them.
and yea.... probably should have said it drives the same at the beginning of the thread.
Old Mar 24, 2014 | 07:02 PM
fishEH's Avatar
I have an RTE adjustable panhard and it chewed through 3 different brand heims. Now they weren't terrible and if I drove the truck strictly on dirt roads and trails they would probably be fine. But there was more play in them than I cared for. I ended up finding a bushing rod end from Speedway Motors for about $13. I have to ream the frame mount out to accept a 5/8" bolt but otherwise it's perfect and has outlasted all three of the previous heims.
