New Oil Leak
Old Sep 15, 2010 | 08:25 AM
okdiscoguy's Avatar
So your valve cover bolts are tight?
I agree with the above. Belts and hoses with a coolant swap. Also check all of your pulleys. I was having no signs driving at all, but go through my engine monthly. Took the serpentine belt off and the water pump was about to loose the shaft. Bearing was toast and I couldn't tell until I checked by hand.
Old Sep 15, 2010 | 10:43 AM
Jull's Avatar
Same here. Did my check up before I left for my fishing trip last July and noticed the bearing was loose on the water pump. I ordered a new pump but the shaft broke off the next day.
Old Sep 15, 2010 | 03:04 PM
tweakrover's Avatar
I think it was auto zone that has the gasket and it comes with the 2 rubber end caps and some rtv all in the same kit.
Old Sep 15, 2010 | 06:02 PM
Danny Lee 97 Disco's Avatar
Thanks to all for your helpful input, that is the kind of info I was hoping for.
I replaced the serp belt a few months ago and was already figuring on getting a hose kit from AB unless I find a better deal of all of them since I am unsure of them ever being replaced.
Also time to pick up an oil filter and change oil as well. I probably will go ahead and grab the fan clutch that Spike mentioned, the $50 one from AutoZone. So I guess I'll see what all they can provide.
I have to get a socket to tighten the valve covers with as well. Isn't that a 10 mm 12 point 1/4 drive deep socket that is recommended? Got to order one of those, can't find one in stock anywhere, NAPA said they could get one in a day or so.
Old Sep 16, 2010 | 06:56 AM
Jull's Avatar
It's a 12 point 8mm socket in 1/4 drive. I'm having a real hard time to find one.
Old Sep 16, 2010 | 07:09 AM
DiscoJag's Avatar
Talking Oil leak ? What oil leak ?
I think a 5/16 12 point socket will also work. I just had a leak from my valve covers. They seem to loosen up by themselves. I'm trying some Locktite on them this time. I feel like getting some of those old hot rod long wing nut tighteners for the valve covers so I could tighten them up every couple of days - no room though. ;^)
Old Sep 16, 2010 | 08:53 AM
okdiscoguy's Avatar
They will loosen by themselves. That is why I keep saying to check them before ordering anything else. I tighten mine every oil change.
thearmlesswonder
Jul 27, 2015 10:16 AM
Phatrowles
Jan 9, 2014 10:36 AM
shonuff93
Mar 28, 2012 09:33 AM
tito5590805
Sep 27, 2010 11:32 AM
rgrizzard
Mar 6, 2008 10:16 AM
