new to working on cars
Old 09-16-2010 | 08:38 AM
davidstereo's Avatar
Default new to working on cars
Is a t box the same as the transfer case? If so how do I change the fluid in mine... I'm getting the clunk that everyone seems to get on these. Pictures would help if anyone has them. Thanks, Dave
Old 09-16-2010 | 08:42 AM
Long Haul's Avatar
Ive never heard it called a "t box" before but I guess to each his own......heres a write up th oil change though
https://landroverforums.com/forum...ad.php?t=27159
Old 09-16-2010 | 08:59 AM
okdiscoguy's Avatar
Check the tech sticky at the top. There is a lot of info there.
The RAVE manual is a free download in my sig. It has a wealth of info too..
Old 09-16-2010 | 09:13 AM
Thanks guys, I am heading outside to do it right now if I have any problems I will let you know. Dave
Old 09-16-2010 | 09:29 AM
Long Haul's Avatar
Just make sure the fill plug comes out before you drain the oil!!
Old 09-16-2010 | 10:01 AM
Yes. Now go to the top of the Discovery section, find my list of items for a major service and do them all. If you have any questions, PM me your tele number and I'll be glad to help you.
Fir your current issue, also grease all your drive shaft grease fittings.
Old 09-16-2010 | 12:18 PM
just got home with the new lube. quick question? Is the nut on the right hand side of the picture in the thread provided the drain plug? I have the fill plug off and don't want to take the wrong nut off. the pic i'm referring to is transfer case 004. thanks, Dave
Old 09-16-2010 | 01:19 PM
ok I have new fluid in it. It was really low. Should I be worried? the fluid that came out was completely black. Also, disco mike I couldnt find your link with suggested maintanance? Could someone give me the link? Thanks, Dave
Old 09-16-2010 | 01:29 PM
NiteTrain's Avatar
david, luckily for you the LT230 transfer case is probably the best thing land rover ever built...it should be fine with the new oil unless it was low for a long time and the seals dried out in which case it might leak some now...making it more like every other LR component
Old 09-16-2010 | 01:33 PM
Nevermind, I found it in the disco II area. thanks mike I have pretty much done all of that except the tranny service. Is that just draining the fluid and putting new in? I have bosch premium plug wires all I need to get is the plugs (cant' decide which ones to get yet) and everything on that list will be complete. Oh, I also ordered new igniitiion wires one of mine was dry rotted and fell apart when I touched it. pulled one at a junk yard to hold me until new ones came in.
Quick Reply: new to working on cars
