No Brakes
Old Feb 12, 2013 | 03:36 PM
modem7890's Avatar
Default No Brakes
I had previously posted the problem with my brakes, but I can’t find it. Sorry to start a new thread on the same problem I'm having.
Took my Discovery to a neighborhood mechanic (#1) bled the system, pressure fine. But he suggested I have the ABS checked out.
Two weeks later, no brakes.
Took it to another mechanic (#2) who electronically checked the ABS and found no problems. Bled the brakes.
Take it back to mechanic #2, replaced the flexible brake lines, bleeders and flush and replaced the brake fluid.
Take it back to mechanic #2, replaced both front calipers (his suggestion).
Now should I replace the rear calipers, master cylinder or is it something else? I can get decent pressure it I pump the brakes, but if I need them for an emergency stop, nothing, to the floor. I’m at a loss and my mechanics don’t seem to have any ideas (or their happy me bringing in parts and charging me labor). There are no leaks and driving this thing is dangerous.
Old Feb 12, 2013 | 04:19 PM
Jake1996D1's Avatar
You sure you don't have any leaks??
Old Feb 12, 2013 | 05:09 PM
antichrist's Avatar
What are the symptoms when you lose the brakes?
Old Feb 12, 2013 | 05:13 PM
modem7890's Avatar
Well, I,ve had two different shops work on this problem and they have not told me that they found any leaks. I can't imagine any mechanic letting me drive off with a leaking system. Also, I've checked the reservoir constantly and the level never changes.
Old Feb 12, 2013 | 05:22 PM
modem7890's Avatar
Antichrist
After each repair attempt, the pressure is good, but over next two weeks it gets gradually worse. Eventually, it can go to the floor if I don't have a chance to pump them up.
As an example, in the morning when I back it out of the driveway, there are little or no brakes.
Old Feb 12, 2013 | 07:25 PM
You are loosing brake pressure either from not enough engine vacuum or the master cylinder is bad, it has zero to do with the ABS.
You can confirm this by removed the ABS PUMP fuse from the fuse box under the hood, your problem will remain.
Start with the vacuum booster line, booster and master cylinder.
Always remember to KISS when working on cars, Keep It Simple Stupid.
Brakes work off of engine vacuum, no vacuum, no brakes.
Old Feb 12, 2013 | 07:57 PM
modem7890's Avatar
Spike
Thanks. This makes the most sense since this thing got started.
Old Feb 12, 2013 | 11:40 PM
NZDisco1's Avatar
Sounds like your master cylinder is passing, if the vacuum line from the engine is fine you will need to get the master cylinder re sleaved or replace with a reconditioned one.
Old Feb 13, 2013 | 05:16 AM
amsandunn's Avatar
When you pump the brakes and hold the pedal down does it slowly lose pressure? By this I mean will the pedal go to the floor after holding it for a minute or two?
Old Feb 13, 2013 | 07:17 AM
DiscoJag's Avatar
Get a master cylinder, and not any old aftermarket one.
