No Brakes
Old Feb 13, 2013 | 08:21 AM
antichrist's Avatar
I've never had a bad booster cause the pedal to go to the floor.
You can check the booster easily by applying the brakes in the morning, before you start the engine. Pump them up if you have to. Then, while holding your foot on the brake pedal start the engine. The pedal should move towards the floor some. If it does, the booster is ok.
My bet is on the MC.
Old Feb 13, 2013 | 09:42 AM
modem7890's Avatar
Amsandunn,
After I pump up the brakes and hold it down, it does slowly keep moving, not quite to the floor but I do sense that it's heading there eventually. To me, it sounds like the seals on the master cylinder are worn out (probably due to my negligence by not replacing the brake fluid on this 15 year old truck). I'm going to check the vacuum line first before I order an oem master.
Thank you.
Old Feb 13, 2013 | 04:45 PM
amsandunn's Avatar
I am with everyone else, it screams bad master cylinder.
Old Feb 13, 2013 | 09:13 PM
modem7890's Avatar
Thank you everyone for your input. I really appreciate it. New master cylinder comes next week and I'll post how it turns out.
FightOnUSC79
Nov 26, 2010 09:43 AM
1eyescooter
Feb 1, 2007 11:12 AM
1eyescooter
Jan 15, 2007 08:48 PM
BigMike
Mar 30, 2006 09:45 PM
bakerww
Jan 30, 2005 10:36 PM
