No codes.
Old Jul 10, 2021 | 09:28 PM
Jar9148red's Avatar
4wd High
Default No codes.
After getting a consultant done with a very high dollar scanner, the 1998 disco did not send any information to the scanner. The mechanic said it was the "computer" that was faulty, any ideas on what specific component he was referring to?
Old Jul 11, 2021 | 08:14 AM
stillruns's Avatar
Most OBDII scanners will read the codes? Yours is a 98' so it is just plug and play. You need to own one anyway so you can pull codes when something fishy happens.
Old Jul 11, 2021 | 09:11 AM
jimvw57's Avatar
a generic scanner (not the high dollar ones) may not be able to read the "manufacturer specific" codes, as well as some of the ABS and transmission codes. a 1998 probably doesn't have the ABS or Transmission codes and there is probably a way to get them without a scanner. I have an Autel scanner and it seems to do the job for what I need. Look for one that can display 'Live Data' Computer problems require a specific scanner system to diagnose and fix.
Old Jul 12, 2021 | 06:24 PM
Jar9148red's Avatar
4wd High
I have one, it shows the misfire codes and such, but the one he used was Bluetooth and costs about 5 grand. It said that it wasn't getting any information from the vehicle which is why he said it was a computer issue. He also expressed his hatred for land rover as a brand so he didn't want to spend too much time on it. The disco acts like it's not getting fuel or air even though the fuel pressure is good. The mass air flow sensor is next on the list to try to see if it helps anything.
Old Jul 12, 2021 | 09:35 PM
ononomos's Avatar
You’re going to have to explain more about what the problem is that lead you to need a scan diagnosis in the first place.
What do you mean your Disco “acts like it’s not getting fuel” when you have good fuel pressure? Are your fuel injectors working? What RPMs is your truck idling at?
Old Jul 13, 2021 | 11:31 AM
Robert Booth's Avatar
firstly, I'd run out and buy something like this and mount it on your dash somewhere. UltraGauge OBDII Scan tool & Information Center UG gives you realtime data directly from the OBD2 port. Get the hardwired version.
Once you have realtime data from OBD2, you'll be able to view whats going on with your TPS and we can start to help you debug from there. I've seen a lot of TPS' break.
Old Jul 14, 2021 | 08:09 AM
logan_gibson's Avatar
1998 should have 10as codes, gems codes, abs codes, and srs codes. I don't believe the cruise control ECU stores any codes, but it can be communicated with to see inputs.
There is no ecu for the transmission like on the d2, so no codes there.
Speed sensor is in the transmission and any issues with it are read through the gems.
Old Jul 14, 2021 | 10:52 AM
jimvw57's Avatar
I tried a ScangaugeII on my 1999 (D1) and it couldn't read all the codes. my Autel does a better job, but still won't do everything the expensive ones will
kristofferzen
Oct 28, 2015 12:21 PM
cobbcj7
Oct 10, 2014 12:50 PM
JEFIII
Sep 8, 2010 09:12 PM
Foe
Jul 7, 2009 07:54 AM
wildhorses
Oct 18, 2005 04:26 AM
