OBD II codes
Old Jul 5, 2009 | 05:40 PM
Foe's Avatar
Foe
Default OBD II codes
Hello All.
Did a search of forums and was surprised to find no matches for "OBD". I searched the net and found OBDII codes for Disco 1's, but came up empty handed for Disco II's. Are they the same?
If not, does anyone have the OBDII codes for a 01 Disco?
Thanks in advance
PS I'm buying my first LR tomorrow for (what I believe) is a heck of a deal. I'll post pictures and info after I get her home!
Old Jul 5, 2009 | 05:51 PM
Torancis_LR's Avatar
Originally Posted by Foe
Hello All.
Thanks in advance
Foe, are you looking on advices of which OBD scanner is good for purchase or the list of error codes?
Here is the list by antichrist https://landroverforums.com/forum/sh...ighlight=p1412
Can't wait to see your new truck!
Old Jul 5, 2009 | 05:54 PM
Foe's Avatar
Foe
No I have a scanner. I needed the codes. Thanks for the QUICK response!
Old Jul 5, 2009 | 05:55 PM
No I have a scanner. Need the codes. Thanks
Yeah, scroll to about the middle of the page of the thread I gave you.
Old Jul 5, 2009 | 06:45 PM
You can also bookmark this site.
http://mechanicdoctor.com/
https://landroverforums.com/forum/sh...ad.php?t=21328
Old Jul 6, 2009 | 09:02 PM
Foe's Avatar
Foe
Check out my album to see my $3K steal I got on the 01 Disco SD
Old Jul 6, 2009 | 09:22 PM
I would suggest that since you have no idea about OBD2 codes that before you try and fix something you run the code numbers by us.
Hopefully you have picked up on the fact that nearly OBD2's codes are the same for most vehicle.
My concern is that till you figure out how the codes work together you may waste a lot of money.
Old Jul 6, 2009 | 10:37 PM
Foe's Avatar
Foe
Yeah I know that OBD2 codes are same for most vehicles, just didn't know about the foreign (Global codes). Now I do.
I have a P0441 code which I've researched a bit and it appears it could be one of many things . I'm going to have it looked at by the garage and see what they can trace it to.
Thanks for the concern/help.
Old Jul 7, 2009 | 07:54 AM
441 is an incorrect purge flow, probably start with testing the purge valve.
johnkbl
May 3, 2010 06:19 PM
alemurill
Jul 9, 2008 10:16 AM
AndyTeez
Sep 2, 2007 10:42 AM
mikedemet
Apr 13, 2006 01:05 AM
miishmiish
Mar 8, 2006 12:31 AM
