No crank
Old May 23, 2024 | 01:36 PM
Navadino's Avatar
8th Gear
Default No crank
Just put my 1998 back together after doing head gaskets and it won’t crank. I can hear 2 relays clicking. One under the drivers seat and one in the passenger footwell. Check voltage to the starter and have 0 volts to the smaller wire when in the start position. I am able to get the car to crank by jumping power to the solenoid. Where is the next step ?
Old May 23, 2024 | 02:57 PM
Navadino's Avatar
8th Gear
I can also get the car to crank if I jump from pin 87 to 30 at tue relay. I bench tested the relay and the relay works. What would cause no power to the relay?
Old May 23, 2024 | 07:09 PM
JohnZo's Avatar
Maybe a blown fuse or wiring or ignition switch problem. The wiring diagrams are very helpful for this, otherwise just guessing, but check for a blown fuse first.
Old May 24, 2024 | 07:57 AM
Navadino's Avatar
8th Gear
Got it to start by grounding the ground pin at the starter relay. But the car won’t accelerate and the Speedo doesn’t work. Could this all be anti theft system ? Looking at the wiring diagram the anti theft system interrupts the ground to the starter relay. Does the antitheft system also keep the car from running correctly?
Old May 24, 2024 | 08:38 AM
Navadino's Avatar
8th Gear
Ba
Bank 1 fuel trims are way high. When doing the head gasket I found the bank one cat element was loose so I emptied it out could this be causeing the fuel trims or are fuel trims only controlled by upstream 02s?
Old May 24, 2024 | 09:46 AM
WaltNYC's Avatar
Since you did the head gasket you should re-set the adaptive values. Allow the computer to 're-learn' the engine. Now it is using old data/algorithm on a 'new' engine.
This thread will help
https://landroverforums.com/forum/di...68/#post704705
Old May 24, 2024 | 01:04 PM
JohnZo's Avatar
Regarding your question, trims are controlled by the upstream sensors only.
Short term trim stuck near 25% might indicate a faulty O2 sensor. That happened on my 96.
Old May 31, 2024 | 12:03 PM
Navadino's Avatar
8th Gear
is there a good location for a windows download of robertfs app? obd wire is on the way but cant seem to find the download for his app on windows
screem22
LR4
Dec 6, 2023 08:24 AM
eglicomet
Defender
Jun 18, 2020 05:17 PM
Martin Shields
Feb 1, 2020 08:11 AM
sickws6
Range Rover Classic (1st Gen)
Nov 10, 2019 05:26 PM
jisenb
Dec 21, 2013 02:55 PM
