No instrument lights...
Old Mar 10, 2011 | 12:19 PM
Dodger's Avatar
Default No instrument lights...
the other day I drove over a hard bump in the road and my instruments lights went out. The #8 fuse blew, and now that circuit is shorted out. Do these trucks commonly short out this circuit? I am open to suggestions as to where to start looking for the short. Hoping I do not have to pull the dash out! Thanks,
Dodger
Old Mar 10, 2011 | 12:41 PM
jafir's Avatar
Check the light in the glove box, I think I remember talk about it shorting out.
Old Mar 10, 2011 | 12:44 PM
Dodger's Avatar
will do, thanks
Old Mar 10, 2011 | 07:13 PM
Danny Lee 97 Disco's Avatar
Just the other night, all my dash lights went out when I turned the headlight on. I wiggled the headlight stalk switch a little and they came back on. Sounds like my switch may have some excess wear in it.
Old Mar 10, 2011 | 07:35 PM
Rover Chris's Avatar
a worn headlight switch will cause a loss of lights but it wont cause a fuse to blow. that requires a direct short to ground or an overloaded circuit.
Old Mar 11, 2011 | 07:33 AM
Dodger's Avatar
It is under the dash somewhere, I removed the cluster and found a few bare wires rubbing on the support. I fixed them, replaced the fuse, they worked till I hit another bump. Then I removed the cluster again, installed split conduit on all the wires, and put it back together again. Replaced the fuse, they worked again till I hit a bump. My guess is that I will need to pull the dash and just check all the wiring. I guess I know what I am doing this weekend...
Dodger
Old Mar 12, 2011 | 11:57 PM
there is a company called power probe that makes automotive electronics tools and equipment, and they make a device specifically for locating shorts, I have never used it and have no idea how much it costs but it may be worth looking into. I will say that I have a few of there products and am pretty happy with them.
Old Mar 13, 2011 | 07:23 AM
geek_IM's Avatar
2x on the headlight switch, I'd be looking there first being a wear part.
Old Mar 13, 2011 | 10:28 AM
I am going to warn you up front, finding shorts is the absolute worst part of what I do, I honestly would say that more than 50% of those situations I end up running a new wire to bypass the short. I suggest studying the schematics, locate and disconnect all the connectors on that circuit and test the wires for ground. that will help you pinpoint where the short is.
Old Mar 13, 2011 | 12:24 PM
Dodger's Avatar
I own the complete power probe kit. The short finder is pretty much usless on circuits with lightbulbs in them. It will mistake the bulb for a short.
