No Start, No Click, No Crank, Fully Charged Battery
Old 11-08-2021 | 04:17 PM
DiscoNewbe's Avatar
Originally Posted by Toran
My to-do-list kept growing and at the time I needed to have that truck up and running!
I wired a push button directly to the starter. The push button is located inside the truck. I turn the ignition on and simply push the button to start the truck. The truck will turn off as normal with the key returned to the off position.
I still have yet to track down the shortage in the actual ignition switch for a proper fix. With that being said the truck is operational and the push button works everytime.
@Toran Thank you for that! But where did you run the wire from?
You connected the wire to the spade/blade terminal on the starter?
If I can’t get my running soon I may have to try this trick to make it home haha. Thanks!
  #32
Old 11-08-2021 | 06:06 PM
Toran's Avatar
Wire connected from starter to positive battery.
Wire connected from positive battery to push button positive.
Wire connected from ground connected to push button ground.
DiscoNewbe (11-08-2021)
Rossmphoto
06-30-2020 07:49 AM
post42
05-07-2014 08:46 PM
Baylink
09-11-2013 08:06 PM
pinkytoe69
09-05-2013 01:36 AM
pvenuti
09-30-2011 10:01 PM
Quick Reply: No Start, No Click, No Crank, Fully Charged Battery
