No Start, No Click, No Crank, Fully Charged Battery
Old Nov 8, 2021 | 04:17 PM
  #31
DiscoNewbe's Avatar
Originally Posted by Toran
My to-do-list kept growing and at the time I needed to have that truck up and running!
I wired a push button directly to the starter. The push button is located inside the truck. I turn the ignition on and simply push the button to start the truck. The truck will turn off as normal with the key returned to the off position.
I still have yet to track down the shortage in the actual ignition switch for a proper fix. With that being said the truck is operational and the push button works everytime.
@Toran Thank you for that! But where did you run the wire from?
You connected the wire to the spade/blade terminal on the starter?
If I can’t get my running soon I may have to try this trick to make it home haha. Thanks!
Old Nov 8, 2021 | 06:06 PM
  #32
Toran's Avatar
Wire connected from starter to positive battery.
Wire connected from positive battery to push button positive.
Wire connected from ground connected to push button ground.
Rossmphoto
Jun 30, 2020 07:49 AM
post42
May 7, 2014 08:46 PM
Baylink
Sep 11, 2013 08:06 PM
pinkytoe69
Sep 5, 2013 01:36 AM
pvenuti
Sep 30, 2011 10:01 PM
