Not a bad alternator after all!
I'd noticed a bit of noise from front top center of the engine that I assumed was alternator bearings. Luckily, I had talked the previous owner into a NAPA lifetime after finding he was replacing the O'reilly lifetime every month for about a year!! So, I ordered one in and finally got time tonight to change it, but the looseness in the tensioner pulley caught my attention first. When I went to spin it - it didn't! The alternator sounds and feels good, so I pulled the tensioner off, popped a seal off the 6203 bearing and found my answer - full of dry brown crud. I was all excited to push the bearing out and---damn, I remembered I'm home, the bearings are at work and the wifes away with the other car
. So... I sprayed a little penetrant in to loosen up and flush the crap out, threw a bit of Valvoline blue grease in there, popped the seal on and buttoned it up - I'll change it tomorrow at work - and it sounds perfect!! But it will be replaced tomorrow - I wouldn't trust it 20 miles out of town! But the pulley is a good heavy cast item that is well worth rebuilding rather than the light duty plastic and stamped stuff I have available through Gates. It is pretty close to the quality they are using on Cummins though - we might have a HD option - but that will wait for another day. I stock at least 8) 6203 2RSJ SKF bearings so an easy and cheap repair - I'll probably throw one in the parts stash too - an easy trail repair if needed.
I'm still impressed with the simplicity and straight-forward design of my Discovery though - sure there are "quirks", but the rebuildable aspect of about everything is unheard of in other modern cars.
I've got an appointment Monday to get a new windshield installed ($316.00) and then to replace panhard rod bushings - they are the primary source of my panic-stop shudder - leaning towards urethane.. any thoughts. Russ
. So... I sprayed a little penetrant in to loosen up and flush the crap out, threw a bit of Valvoline blue grease in there, popped the seal on and buttoned it up - I'll change it tomorrow at work - and it sounds perfect!! But it will be replaced tomorrow - I wouldn't trust it 20 miles out of town! But the pulley is a good heavy cast item that is well worth rebuilding rather than the light duty plastic and stamped stuff I have available through Gates. It is pretty close to the quality they are using on Cummins though - we might have a HD option - but that will wait for another day. I stock at least 8) 6203 2RSJ SKF bearings so an easy and cheap repair - I'll probably throw one in the parts stash too - an easy trail repair if needed.I'm still impressed with the simplicity and straight-forward design of my Discovery though - sure there are "quirks", but the rebuildable aspect of about everything is unheard of in other modern cars.
I put in urethane, and am very happy with them. There are a bunch of posts saying that they squeak, I just coated them with handfuls of never-seize before i put them in, and haven't had any issues.
I did have a hell of a time getting the snap-rings out of the tensioner to change the bearing, and then getting it back in.
You have the same issue?
I've had even worse luck using aftermarket pulleys, especially some that fit terribly, or looked really cheaply built.
..leaning towards urethane.. any thoughts?
I know Your Disco isn't a Corvette used for racing, but thought still worth sharing. Other than that, I don't have any personal real-world side-by-side comparisons to say one way or another. Chances are, new rubber bushings will last as long as you ever own the rig. Urethane might too. Urethane bushings seem to be generally less expensive. I'm guessing they are easier/cheaper to manufacture (??).
Oh yeah- that thing is a pain! I tried for a half hour, before heading back to work and grabbing a NAPA 38033 pulley (@ 1mm larger OD) and bolting it back together - my wife was a bit restless to head up to a local hot spring! The next day, I took an 1/8" drill bit and drilled 3 holes on an angle to line up with the back side of the snap ring so that I can get behind it and push out - so much easier! Russ
J P Cook
Jun 4, 2014 09:40 AM
Evan5291
Jul 26, 2011 06:06 AM
JumPeR04
Dec 17, 2009 07:57 PM
mgabriel
Dec 11, 2008 11:53 PM
