Not starting
Old 01-16-2016 | 02:41 PM
ihscouts's Avatar
Good job. Should run better than it did before it died too.
Old 01-16-2016 | 02:45 PM
aemnky606's Avatar
I hope so. Now need to get the brakes to hold pressure then its on the road.
Old 01-16-2016 | 02:54 PM
ihscouts's Avatar
What's up with the brakes not holding pressure?
Old 01-17-2016 | 08:50 AM
aemnky606's Avatar
I have to bleed them every few weeks. The pedal does not move at a red light, but will have air in the front a lot. I have to add fluid to the front half of the tank at the same time. The fluid is going some place but I can not find it. I am going to start with a rebuild kit for the front calipers and new lines.
Old 01-17-2016 | 10:15 AM
ihscouts's Avatar
I've been there done that. Should see brake fluid trails on either inside tire wall. If the new pucks and seals don't work because of the caliper bores then it's new/reman calipers. I bought a used set of fronts from Paul Grant and haven't had any issues in several years now.
Old 01-17-2016 | 11:14 AM
aemnky606's Avatar
I was thinking of just getting new/used ones, Paul just put up a post about parting out a 97.
Old 01-17-2016 | 12:56 PM
ihscouts's Avatar
Bingo and it sounds like a gem so give em a shout.
Old 01-17-2016 | 01:46 PM
aemnky606's Avatar
I sent a pm and waiting to hear back.
lazerbrains
LR2
38
08-09-2023 07:54 PM
readdiscovery
07-07-2006 05:23 PM
nick
Freelander
03-14-2006 04:41 PM
pants
10-19-2005 12:47 AM
nick
07-17-2005 02:04 PM
Quick Reply: Not starting
