Not starting
Not starting
Ok guys,
I have done a few searches on this topic and I have seem to boil it down to the crank shaft sensor but I just want to run it by y'all before I toss parts at her.
First off it has not been on the road in a year as I do some much needed work. I started off replacing front main seal, oil pump, timing chain and gears, water pump, all hoses, fan clutch, new fuel pump, 2 inch lift, and a bunch more.
I have had it running for several months and will drive it down the street every week or two to keep from just sitting. It started just fine yesterday morning, but today when I went to start it and it would just crank and act like it would catch and then just keep turning over. I have fuel at the rail and good battery. I believe I have spark by the way it will catch for a second. So I think the next thing to do is change the crank sensor, am I on the right track here?
