not starting, just clicking
Old May 17, 2011 | 01:58 PM
rover11's Avatar
If it stalled it's possible that it is the alternator, but if that was the case you would have a dead battery... Are you sure your battery is charged? Do you have a charger just incase?
Old May 18, 2011 | 07:39 AM
AAD2's Avatar
8th Gear
I do have a battery charger... but I haven't actually tested it yet (it's been raining non-stop here in NJ for days now), but the headlights and interior lights were still pretty bright yesterday, and she died on Saturday evening.
I'm going to check all the contacts and wires as soon as I can get a few minutes without it pouring rain, but I feel like a starter replacement is about to happen...
Old May 18, 2011 | 08:10 AM
AAD2's Avatar
8th Gear
Anyone have any experience with this website: ?
The price is not to much more expensive than AutoZone (which I really don't like using).
What do you guys think?
Old May 18, 2011 | 08:31 AM
rover11's Avatar
It really could not hurt to check the battery. Just because the headlights were bright doesnt mean the battery doesn't have enough juice to turn over.
Old May 18, 2011 | 09:33 AM
AAD2's Avatar
8th Gear
I'm checking the battery and the wires first. But I would also like to prepare myself for the worst case.
Mikes 60k service is starting to look like my weekend plans...
Old May 18, 2011 | 09:47 AM
turf63's Avatar
Unused the autozone starter. It took a little to figure out how to put it in but then when the starter died again a year later (I got a new free one from autozone, lifetime warranty) it went in lickety split. The good news is of you get the autozone refurb, If it dies, you get another for free, and you just get better and installing and removing the starter. I can uninstall in like ten minutes now. Practically a pro
Old May 18, 2011 | 09:50 AM
turf63's Avatar
225 is a lot more than I payed for the autozone one, double? But that solenoid is way bigger than the one on the AZ starter. Probably a lot more cranking power. Less likely to die
Old May 18, 2011 | 10:03 AM
Danny Lee 97 Disco's Avatar
With mine, it was intermittent until I redid the ground connection from the starter to the frame. These things are terrible about corrosion in that area. I would redo the battery ground cable as well as the starter ground connections first.
As far as the grinding noise, Tom is saying that the Bendix (which moves forward and engages the flywheel) may be stuck forward and that may be the grinding you heard.
You will find that as you start to work on one item, several more conditions that exist will reveal themselves.
I would advise a good detailed inspection front to back underneath with a good light and a comfortable creeper. Wear eye protection as well. See what conditions exist and clean, inspect, and take on major items that exist.
I usually buy all new mounting hardware whenever I replace anything. Also buy lots of PB Blaster when it is on sale. You will need it.
When dissassembling things, clean it up good, spray it well for a few days, allowing it to soak in, use as long a lever arm as possible and proceed slowly and carefully as you work thru it.
Have fun with your new addiction!
Old May 18, 2011 | 10:04 AM
If you need a used alternator or starter let me know, I can save you some money on these types of items.
Old May 18, 2011 | 10:10 AM
antichrist's Avatar
For starter replacement on the V8's I highly recommend the Denso gear reduction starters from Britishstarters.com. Cheaper than OEM, better starter, and better warranty.
lazerbrains
LR2
38
Aug 9, 2023 07:54 PM
Vicky Fleming
Dec 29, 2014 12:27 PM
cheqbay1997
May 6, 2014 10:09 AM
domyo
Sep 25, 2008 12:19 PM
rjennings
Aug 31, 2008 08:15 AM
