Nuts/Bolts for connecting y-pipe to muffler?
Old Jan 17, 2017 | 08:28 PM
LeakyDisco's Avatar
Default Nuts/Bolts for connecting y-pipe to muffler?
Any recommendations for nuts/bolts suitable for connecting an aftermarket y-pipe to an aftermarket (both Magnaflow in my case)?
The original setup had studs in the y-pipe, which is not present in the new setup.
So, size and grade is what I am looking for help with.
Thanks.
- Chris
Old Jan 21, 2017 | 06:48 PM
LeakyDisco's Avatar
Default Answer
I chose M10 bolts (~2.5 inches in length) and nuts with a flat and split washer. They appear to fit well but it almost looks like M12 might work as well and be a bit more snug in terms of the inner diameter of the muffler to y-pipe flange holes.
Plan is to get the new exhaust system in within the next 2-3 weeks (weather/time permitting), so I will have a final report on the bolt size here once I'm convinced what actually worked.
Charlie_V
Aug 27, 2015 12:25 PM
dcarr1971
Feb 8, 2013 08:16 AM
robersonb
Jan 2, 2013 01:43 PM
tornado_735
Mar 5, 2009 04:39 PM
raid13
May 13, 2007 12:13 PM
