Size of the bolts/nuts connecting the front shaft to the diff?
Old Mar 4, 2009 | 05:24 PM
tornado_735's Avatar
Default Size of the bolts/nuts connecting the front shaft to the diff?
I looked for it, but I might have missed it. I want to take the front driveshaft off, but before I go down and jack the Disco up, I was wondering what size wrench and ratchet I need.
Thanks
~Aaron
Old Mar 4, 2009 | 05:42 PM
IDAHODISCO's Avatar
I think it a size 14! don't us a open end wrench to turn the nuts it will strip it us a ratchet and socket.
Old Mar 4, 2009 | 05:48 PM
malmberg's Avatar
I think that you will need a 14mm and 15mm socket. You may have to hold both ends closest to the front diff.
Old Mar 4, 2009 | 05:49 PM
malmberg's Avatar
I forgot that I also used a 14mm wrench.
Old Mar 5, 2009 | 05:52 AM
Thanks guys. I had to work the Graveyard shift last night, so I am too tired to mess with it right now. I'll get some sleep, and pull that driveshaft off today.
Depending on what shape that shaft is in (I haven't taken a super close look at it), you think it might be possible to rebuild it if it's not too badly damaged? Just a thought I had while I was mopping the floor at work tonight.
Old Mar 5, 2009 | 10:24 AM
You could have answered your own question by just crawling under your truck like the rest of us do.
Old Mar 5, 2009 | 04:39 PM
Oh thanks Mike. I'll make that decision based on my 6 days worth of knowledge on the Discovery. Maybe I should phrase it like this:
Is it safe to rebuild a driveshaft that has previously failed, no matter if the shaft looks damaged or not ?
That make any better sense?
Charlie_V
Aug 27, 2015 04:43 PM
dcarr1971
Feb 8, 2013 08:16 AM
rsomp
Jun 14, 2012 12:45 PM
bcolins
Apr 19, 2011 06:40 PM
tex599
Aug 30, 2009 10:24 AM
