o2 sensor upstream '96 disco SE
Old Mar 14, 2013 | 08:55 AM
aeroschmitz's Avatar
3rd Gear
Default o2 sensor upstream '96 disco SE
any tricks for disconnecting upstream O2 sensor from main harness (the connection is in back of coils and down on engine/transmission bell housing)?
Old Mar 14, 2013 | 05:37 PM
jastutte's Avatar
small hands and lots of patience. or remove the coil packs. i was able to unplug and replug the O2 sensors with the coil packs still in place, but came away with scraped and bruised hands. if i recall unplugging the sensors was much more of a pain than plugging them back in. my truck is a 96 as well.
Old Mar 14, 2013 | 08:44 PM
Pay someone else to do it.
Old Mar 20, 2013 | 08:47 AM
3rd Gear
are upstream and down stream o2 sensors physically the same except for connectors on '96 discos???
Old Mar 20, 2013 | 09:23 AM
No, they are 2 different style 02's and are not interchangable. Also use anti-seize on the 02's threads and die electric inside the connection to keep oil out.
Old Mar 20, 2013 | 11:14 AM
fishEH's Avatar
Open the hood. Use a ratchet strap or whatever tired back to the roof rail to open the hood further than just the prop would allow.Jump up in the engine bay and remove the coil pack. This will give you the access you need to disconnect the O2 sensor plugs.
Edit: I missed Jastutte's reply. But yeah, remove the coil pack.
Old Mar 20, 2013 | 11:50 AM
pinkytoe69's Avatar
Taking some of the wires out of the coil pack will also give u a little more finagle room.
The other option is to get underneath and snake your arm around the tranny.
Old Mar 20, 2013 | 06:47 PM
Sorry, wrong, the DI uses the same sensors front and rear, the DII does not.
Range Rover Oxygen Sensor (Same Fit As Genuine Part # AMR6244)
Land Rover Parts, Accessories and Information
OXYGEN SENSOR LAMDA P38A RANGE ROVER & DISCOVERY I 4, RND290, ERR1834 - Land Rover Parts | Rovers North
Old Mar 21, 2013 | 11:07 AM
3rd Gear
thanks for the correction note, that is good info to know. I'm guess I'm lucky that I'm on my 5th rover and one of these sensors finally crapped out.
csp
Jul 18, 2013 05:18 PM
Smith CH
May 28, 2013 06:35 PM
archaeology_student
Apr 14, 2013 01:51 AM
javasteve
Feb 24, 2013 09:36 AM
Discolife
Dec 3, 2011 09:49 AM
