OBD II Scanner
Old Feb 10, 2013 | 01:17 PM
dsmeddy's Avatar
Default OBD II Scanner
Which code scanner would be best for scanning a 1997 Disco?
Old Feb 10, 2013 | 02:38 PM
They are not year specific other that as long as the vehicle is a 96 or newer, they will be OBD2.
That being said, depends on what you are wanting to do and your experience with a scanner.
A good Scanner, my choice, is the Innova 3130 found on Amazon for around $130.
Old Feb 10, 2013 | 03:45 PM
jastutte's Avatar
i like the ultragauge. fairly inexpensive and you can set it up to monitor quite a few sensors in real time, the real coolant temp being one of the more important ones. has saved me a few dollars and helped narrow down some preexisting problems.
Old Feb 10, 2013 | 09:26 PM
dsmeddy's Avatar
I ordered the Ultra Gauge, we'll see how it does.
Thanks
Old Feb 11, 2013 | 12:21 AM
The UG will make it easy to watch coolant temp, you can see on this pix that scanner and gauge might not read what you would think. Scanner speak the truth.
ShortTom
May 21, 2012 10:45 AM
thechidz
Jul 2, 2010 08:35 PM
LRScott
Dec 26, 2009 01:08 PM
stu44mag
May 25, 2009 09:53 PM
KevC
Jan 20, 2007 08:21 PM
