Odd noise from engine
Old Jul 21, 2010 | 10:08 AM
Danny Lee 97 Disco's Avatar
Did you replace all the vacumn hoses?
My EGR hoses were starting to deteriorate from the inside walls. You might want to take a look at those as well if they are originals.
Old Jul 21, 2010 | 10:09 AM
Another question, how do you guys post such large pics? I use the manage attachments button and don't get the same results, just the little thumbnails, up to five at a time. Is there some trick to putting the larger pics in the middle of a posting?
Old Jul 21, 2010 | 10:11 AM
ColoDisco's Avatar
I replaced 2 complete vacuum lines. 1 from the back of the intake to the fuel pressure regulator. 1 from the intake to the vacuum advance on the distributor.
3rd leak was to the cruise control, again. I fixed that one before and it cracked again. I will have to buy some new lines and just replace them all. I did check the breather lines and while stiff they did not feel compromised yet.
Old Jul 21, 2010 | 10:16 AM
ColoDisco's Avatar
I hosted my pic on photobucket. Have a app for that.
I just linked the image direct to photobucket. ie [img][/img]
Old Jul 21, 2010 | 03:23 PM
tornado_735's Avatar
5w-anything is too thin for these engines!
Old Jul 21, 2010 | 05:06 PM
Danny I went into great detail for you on how to post large pics the last time you asked.
It is in the "cabin filter" thread.
Old Jul 22, 2010 | 08:42 AM
Silver_Slug's Avatar
Glad to have finally been some help ;-)
Old Jul 22, 2010 | 08:43 AM
i run 10W-30 the edge one 75,000 PLus one Castrol i've always used Castrol for my bimmer so why switch now? It seems to be good.
Old Jul 28, 2010 | 05:00 PM
ColoDisco's Avatar
Ok. Back from the trip and all went well. Still have the whooshing noise. Only real wrinkle I had was the transmission seems to have stuck in 3rd after climbing monarch pass on the way home. I could shift to P,N,R and D however in D it stayed in gear and did not switch to OD or 4th or whathavyou. after decending about a mile it finally found OD. I think the transmission was too hot and locked into a gear. I have alot of pics and video which I will post later. Any other insights into this? I am starting to think the whoosh and the trans issue are related. Perhaps I need to record it and post it.
Old Jul 28, 2010 | 08:54 PM
Where is the whoosh coming from?
How long does it last?
When exactly does it do it?
