oil change problem...please help!
Old Aug 26, 2013 | 01:45 PM
EricTyrrell's Avatar
Rocker covers are common leak sources. Hoses too. Just look very carefully.
A common strategy is to clean the engine very well so you can see where new fluid is coming from.
Old Aug 26, 2013 | 07:44 PM
TOM R's Avatar
Rear lower intake seal/valley seal?
Old Aug 27, 2013 | 10:30 PM
Motorvated's Avatar
I have sprayed the entire underbody with royal purple and power washed it. Vehicle is sitting over clean (for now) cement so I can try to pin point where all the oil is coming from.
Old Nov 15, 2013 | 04:14 AM
Walko327's Avatar
MOTORVATED, im a little late to this party but you may want to check the oil pressure switch. mine leaked like a sieve from a release valve on it though it was small it sprayed the area with oil all over. it sits above the filter and can really make a mess.
Old Nov 27, 2013 | 10:23 AM
san988's Avatar
I agreed with Walko327.
I was going to install an oil pressure gauge and the nut left to the oil filter just above the OEM oil valve was loose. I have tighten the nut and cleaned the area with a grease remover and no more oil.
Old Nov 27, 2013 | 11:28 AM
antichrist's Avatar
And also not "everyone" recommends the huge purolator. I recommend Wix 51515 or Baldwin B2.
Old Nov 27, 2013 | 11:59 AM
WaltNYC's Avatar
Which, I am told, is the same as Napa Gold 1515. (which I use and is easy to find)
Old Nov 28, 2013 | 06:43 AM
antichrist's Avatar
Yes, Wix rebrands the 51515 for NAPA, also for Carquest, but I don't know that PN.
collin Barrows
Aug 28, 2011 07:13 AM
sawadeh
Jul 2, 2011 08:10 PM
avking
Jan 1, 2009 02:45 PM
Davey
Oct 19, 2008 05:56 AM
btbaus
Oct 8, 2008 09:20 PM
