Oil Changes
Old Nov 23, 2010 | 12:18 PM
Dezert Rover's Avatar
Default Oil Changes
I was reading in my owners manual about the proper oil change procedure.... it said NOT to remove the oil filter w/ the engine drained in order to prevent draining the oild pump.
How are you supposed to do that w/out getting oil all over the place?? Is this common LR practice?
On other vehicles, I've always drained the engine, then removed and replaced the filter, then refill.
Old Nov 23, 2010 | 01:32 PM
Chris-bob's Avatar
When I change the oil on my equipment at work, I always remove the old filter, fill the new filter and install, then drain oil and add new oil. In that order. I do this out of convinience because the oil filter is usually not within reach of the drain pan when I'm draining from the drain plug. Less mess.
Old Nov 23, 2010 | 01:39 PM
ColoDisco's Avatar
I have changed my oil 3 times all with this method. No problems.
Old Nov 23, 2010 | 04:07 PM
antichrist's Avatar
What I've been doing for the past 10 years on my '95:
1. Drain oil from sump
2. Remove oil filter
3. Fill new filter mostly full with oil and fit
4. Replace sump drain plug and fill with 6qts oil
5. Remove ignition fuse
6. Crank until oil light goes out
7. Replace fuse and start engine.
About 1/2 the time I just start the engine after step 4.
Old Nov 23, 2010 | 04:56 PM
thanks... it was just kind of confusing. I'm not familiar with the oiling system on these motors and didnt want to hurt anything by firing it up w/ a dry pump.
Old Nov 23, 2010 | 06:20 PM
I do it like everyone else, drain the oil, change the filter, refill the oil, start it up.
Chrisinhouston
Dec 7, 2013 06:10 PM
bmartindale
Jul 30, 2012 06:37 AM
buick215
Jun 13, 2010 07:58 PM
betz470
Nov 2, 2005 10:20 PM
Lisa
Oct 8, 2005 10:17 PM
