Oil leaks
Old May 1, 2020 | 12:35 AM
scott sirota's Avatar
Default Oil leaks
Hi
I have had my 95 disco about 6months. It has 182000 miles on her. Engine has been well taken care of and is the strongest part of the vehicle. I did an oil change recently using a synthetic blend 10w40 and have had problems since.
the plug on the pan won’t tighten all the way. I get to almost snug and it gives way and becomes loose again. I ended up putting a new washer and plumbers tape on the bolt
i am still getting a leak
is it the bolt or pan threads that are failing
slso I am getting oil seepage on the top end as well
nee head gasket? Valve cover gasket? Stop leak fluid? Help any input will help
thanks
Old May 1, 2020 | 12:39 AM
Best4x4's Avatar
I'd never personally run synthetic in an old pushrod LR V8. Rotella 15/40w diesel oil is very good for them or 5/40 (for up north cold weather). Oil Drain Plug wise you might have to get a new plug (hopefully the threads in the pan aren't messed up).
Old May 1, 2020 | 12:42 AM
I didn’t know you could run diesel oil in a conventional motor... I might have to try next time
what’s the best and safest (engine damage) stop leak additive to use anyone?
Old May 1, 2020 | 06:36 AM
Toran's Avatar
Congrats on the Rover and welcome to the forum.
Be sure to check out this sticky link so you can keep her running and on the road.
https://landroverforums.com/forum/di...section-32402/
Old May 1, 2020 | 06:40 AM
stillruns's Avatar
Use the Rotella. Change it out now if you can.
erick846
Dec 1, 2015 11:19 AM
CollieRover
Nov 17, 2014 09:35 AM
Pjpax
Sep 2, 2014 11:22 AM
jruproductions
Jul 27, 2013 09:20 AM
malmberg
Sep 28, 2009 07:24 PM
