Oil Pan tips and tricks
Old Sep 24, 2013 | 03:53 PM
Shiftonthefly1's Avatar
Default Oil Pan tips and tricks
Im about to bolt on my new oil pan. Niether truck had a gasket only black RTV. They both had a thick bead in the middle front and rear. Is this a good idea? Any little tid bits are appreciated.
Old Sep 24, 2013 | 04:02 PM
Scope's Avatar
I used permatex great stuff and it worked like a champ.
Old Sep 24, 2013 | 04:09 PM
EricTyrrell's Avatar
It will seal better than the gasket, but it'll be a nightmare to remove in the future. Pick your compromise.
Old Sep 24, 2013 | 04:46 PM
Extra elbow grease #2 for the 86 bolts.... dab of loctitie on the two bolts that hold on the pickup. Any before and after pix?
Old Sep 24, 2013 | 04:57 PM
Yea I'll toss em on my build thread. Thanks guys as always.
Old Sep 25, 2013 | 06:59 PM
FLA Rover's Avatar
This was recommended to me and what I used when I did mine, no issues!
http://www.permatex.com/products/pro...t-maker-detail
Old Sep 25, 2013 | 08:59 PM
TOM R's Avatar
I used that permatex in a can, makes super easy even bead let it dry minimum 24 hours before adding oil and running engine!!!!
Old Sep 26, 2013 | 10:03 AM
binvanna's Avatar
the silicone rtv is a pain to remove, but I haven't had a problem cleaning up the "right stuff" gasket maker
by the way, it's "right stuff" not "great stuff" great stuff is the expanding foam!
Old Sep 26, 2013 | 05:38 PM
TOM R's Avatar
Asyoucan see from my avatar the permatex works well no water gets in no oil gets out
5bravobravo
Aug 20, 2013 12:11 AM
Snafu / Disco Fries
Dec 1, 2011 11:54 AM
mpparamedic
Jul 24, 2010 06:55 PM
shawn
Dec 21, 2007 11:53 AM
shawn
Oct 4, 2007 09:10 PM
