I NEED TIPS OR TRICKS TO CHANGING TRaNSFERCASE 99 Disco II
Old Oct 4, 2007 | 07:26 PM
shawn's Avatar
Default I NEED TIPS OR TRICKS TO CHANGING TRaNSFERCASE 99 Disco II
I am changing transfer cases on Sat. Got any good tips or asvice?
Thanks,
shawn 99 DiscoDuce
Old Oct 4, 2007 | 09:03 PM
shawn's Avatar
Default RE: I NEED TIPS OR TRICKS TO CHANGING TRaNSFERCASE 99 Disco II
do
What is wrong with your t/case?
Old Oct 4, 2007 | 09:10 PM
shawn's Avatar
I have a crack about 2mm wide 8cm long on the tail end of the transfer housing,next to the e-brake drum. I so not know what caused this. The crack was protected by the crossmember. Maybe the bearing there got hot and craked the housing. I have know idea. I found a used tranfercase and should have it in tomorrow. I have a procedure digram for it, but I always appreciate your advice Disco Mike.
Thanks,
Shawn 99 Disco Duce
5bravobravo
Aug 20, 2013 12:11 AM
Snafu / Disco Fries
Dec 1, 2011 11:54 AM
BFox15
Aug 21, 2011 08:48 PM
mpparamedic
Jul 24, 2010 06:55 PM
shawn
Dec 21, 2007 11:53 AM
