Oil sender leaks: replace or just o-ring or gasket?
96 Disco I SD 130k miles
Finally cleaned it enough to see the oil sender leaking. (Only under pressure)
Before I dive in do you replace the whole sender or can you just replace an "O" ring or gasket?
Thanx to all.
KRMusher
