Oil sender leaks: replace or just o-ring or gasket?
Old Sep 6, 2012 | 08:18 PM
KRMusher's Avatar
7th Gear
Default Oil sender leaks: replace or just o-ring or gasket?
96 Disco I SD 130k miles
Finally cleaned it enough to see the oil sender leaking. (Only under pressure)
Before I dive in do you replace the whole sender or can you just replace an "O" ring or gasket?
Thanx to all.
KRMusher
Old Sep 6, 2012 | 08:29 PM
There is no gasket, there is no o-ring.
It is cracked, replace it, its only $15.
Old Feb 15, 2013 | 12:04 PM
NabisOne's Avatar
Spike, where do you get them for $15?
Old Feb 15, 2013 | 07:33 PM
I got mine from AutoZone.
Spencerfitch
Sep 27, 2020 12:17 PM
TOM R
Sep 15, 2014 03:53 PM
FlyingZebra34
Apr 22, 2013 12:07 AM
patnali
Apr 20, 2013 11:10 PM
discoboy
Dec 20, 2012 02:24 AM
