oil smells like gas
#23
#24
It can be hard to tell if they are bad. The first step would be a fuel pressure gauge. Hook it up and see what pressure you get with it running, and then see how long it holds that pressure with the key off. If it bleeds off quite rapidly, the fuel is going somewhere.... through the leaky injectors, out the pressure regulator/return line, or back into the pump I suppose.
VikingDiesel
04-27-2008 02:45 PM
