oil smells like gas
Old Jun 9, 2011 | 01:34 PM
  #21
jafir's Avatar
well, if it turns out that your injectors are crap, go here:
Discovery Land Rover Fuel Injectors - Land Rover Fuel Injection - FiveOMotorsport.com
Old Jun 9, 2011 | 02:04 PM
  #22
LRD2&ME's Avatar
From: Oklahoma; where the winds come rolling down the plains.
As notoriously failure iminent as the head gaskets are, I would always consider knowing what the compression is like in each cylinder. Slow start, fuel smell? Tune-ups can be costly. Make sure you have no serious issues before you go through all that expense.
Old Jun 9, 2011 | 02:21 PM
  #23
deer killin disco's Avatar
no its not milky. i would be losing coolant if water was getting in the oil right?
how can you tell if the injectors are bad?
im going to do a compression test this weekend
thank you guys for all the input
Old Jun 9, 2011 | 02:31 PM
  #24
jafir's Avatar
It can be hard to tell if they are bad. The first step would be a fuel pressure gauge. Hook it up and see what pressure you get with it running, and then see how long it holds that pressure with the key off. If it bleeds off quite rapidly, the fuel is going somewhere.... through the leaky injectors, out the pressure regulator/return line, or back into the pump I suppose.
norman.j.s
May 6, 2022 09:15 PM
teddyz
Aug 2, 2013 11:53 AM
ejhuerta
Dec 16, 2011 08:14 PM
VikingDiesel
Apr 27, 2008 02:45 PM
Brad S1
Nov 12, 2006 03:21 PM
