Oil on wheels.
Old Oct 21, 2010 | 11:27 AM
Spencerfitch's Avatar
Default Oil on wheels.
I'm getting this on the front AND back. So im wondering is this this differnetial fluid? Or hub fluid? What are the seals called front and back and how difficult is it to change.
On my 4runner you just needed a 12mm aren't and a 2.5" pcv pipe. And it was differential fluid.
Old Oct 21, 2010 | 01:40 PM
antichrist's Avatar
Is it gear lube or grease? They have a different odor.
If it's both wheels on an axle the odds are really good that your axle breathers are clogged and it's gear lube leaking past the axle housing seal.
Old Oct 21, 2010 | 02:09 PM
Along with Tom's question, when if ever have you serviced your diffs. wheel bearing seal and in the case of the front, your swivels?
Old Oct 21, 2010 | 04:48 PM
Never serviced other than new diff fluid
Old Oct 21, 2010 | 06:46 PM
Remove your axle breathers and blow through them with your mouth, sounds like yorui banjo bolts are all rusted up and clogged.
http://www.roverparts.com/Parts/FTC2175.cfm
http://www.roverparts.com/Parts/FTC2176.cfm
dwaned
Feb 6, 2010 03:01 AM
porwig
Feb 25, 2008 10:34 AM
porwig
Feb 25, 2008 10:22 AM
Kooner
Aug 28, 2007 04:51 PM
disco12
Feb 14, 2006 11:35 PM
