Oil on wheels.
I'm getting this on the front AND back. So im wondering is this this differnetial fluid? Or hub fluid? What are the seals called front and back and how difficult is it to change.
On my 4runner you just needed a 12mm aren't and a 2.5" pcv pipe. And it was differential fluid.
Is it gear lube or grease? They have a different odor.
If it's both wheels on an axle the odds are really good that your axle breathers are clogged and it's gear lube leaking past the axle housing seal.
Remove your axle breathers and blow through them with your mouth, sounds like yorui banjo bolts are all rusted up and clogged.
http://www.roverparts.com/Parts/FTC2175.cfm
http://www.roverparts.com/Parts/FTC2176.cfm
porwig
Feb 25, 2008 10:34 AM
porwig
Feb 25, 2008 10:22 AM
Kooner
Aug 28, 2007 04:51 PM
