OK, cheap lift/fj80 coils
Old May 6, 2011 | 03:43 PM
  #101
Mountain Goat's Avatar
Originally Posted by AKdisco
I know rovers are designed to run a skinny tire but I've NEVER regretted going to a wider stance on any other vehicle. Even right now with my roof rack and skinny **** stance I feel like Im gonna flop the truck everytime I go out and F around. Besides that a truck with tires inside the fenders and the body bulging way out just looks UGLY. this is just my opinion.
LOL. I look at the ability to fully tuck the tire as part of the stealth advantage of owning a Rover. And your CG is much lower than you realize, since most of your bodywork is aluminum, and your heaviest components are down low.
Old May 6, 2011 | 03:55 PM
  #102
AKdisco's Avatar
Goat, I believe that on a RRC, but a disco, not so much. i've removed the roof of a RRC and basically its about 50 lbs, not kidding. We made my buddys RRC a full convertible and with the roof gone, rear windows removed, rear door pillars cut off,door glass and power motors removed it was approx 175 lbs worth of stuff. Soooooooo all the rest of the weight on a RRC is on the bottom. I have never cut up a disco but the higher roof, more rear glass, rear heavy door, and the skylight glass makes me believe that a disco will roll way before a RRC will. Anyway, I know the "Tuck" is a rovers secret, but no reason why I cant make a rover thats wide AND tucks...................Hard to do, but best of both worlds
Old May 6, 2011 | 04:20 PM
  #103
Ha, if it's too steep to drive on sideways without tipping, just drive up it. You are right that the RRC is less top-heavy, but the Disco is still not as top heavy as it looks. Yes the roof is steel, yes it has more glass, but by heavy stuff I referring more to the entire drivetrain and chassis. Stock tip-over angle is 45° off-camber. While a wide track would sometimes be nice, the narrow track has it's advantages as well.
PS, I've seen pics a fully tucked 235/85 with a 1.5" spacer behind the stock wheels, and only minimal trimming of the lip. Was a forum member here, don't remember who. That amount of track widening makes sense to me, but I've never had reason for concern about my tip-over angle yet.
PPS, @AKdisco, have you ever had your springs dislocate on you? That's why I haven't disconnected my sway bar yet.
Old May 6, 2011 | 04:27 PM
  #104
AKdisco's Avatar
I know a stock rover has a 45 degree rollover but I'm sure mine with taller tires, 2" of lift, a roof rack with recovery gear is not at 45 degree anymore, but it's still better than I think. Anything over 30 degrees makes most people **** their pants, I've rolled my Blazer on its side and I was amazed at just how far I had to go to make it happen, so Im sure I've always had aways to go before I went over, but still is scary and FUN!!. I've not had my coils dis-locate which only leads me to believe that theres still more flex to be had HAHA!!.
Old May 6, 2011 | 04:38 PM
  #105
Yeah 30° feels pretty extreme. From inside the cab it almost looks like you could reach out and touch the ground sometimes. The owner's manual (if you have one) actually has a very basic but informative guide on off-camber driving.
Oh, I just remembered you have stock length shocks. Did you have to disconnect the shocks to get the springs in? If so, that's why you can't dislocate them. If not, I'm curious to know what the limiting factor is. That's where access to a ramp or a forklift comes in handy.
Like I said, I want to disconnect my sway bar but am concerned about dislocating the coils. So I've been waiting until I have the chance to build dislocation cones, but from what you say that may not be necessary.
Old May 6, 2011 | 04:48 PM
  #106
AKdisco's Avatar
Yeah, stock shocks so YES my shocks are my limiting factor. I'm sure by getting longer shocks I would be able to dis-locate them at will.
Old May 6, 2011 | 04:54 PM
  #107
OK tru, I guess I just need to disconnect mine and see.
Old May 10, 2012 | 11:27 AM
  #108
DrtyDisco's Avatar
Sweet! Picking my fzj80 coils up tomorrow. Can't wait to put them on and see what my Disco can do.
Keep you updated
Old May 10, 2012 | 11:50 AM
  #109
turf63's Avatar
Good Deal, i went this route myself, be forewarned.....they're a gateway drug
Old May 10, 2012 | 04:04 PM
  #110
Danny Lee 97 Disco's Avatar
Originally Posted by Chris-bob
So if a set of springs weighs in at 30#, then shipping with USPS parcel post from Minnesota(I used MN 'cause I know a zip code there) to Here would cost me $35. Sometimes this whole living in Alaska thing sucks, especially when dealing with shipping.
Won't they fit in a flat rate box?
If you want me to, I will check at the yard here in Pittsburgh and see if they have a set.
I can pack them in the same USPS shipping tube with that Brass Bullseye Putter you want. I will even throw in a few irons to go along with it to use at the driving range.
Let me know if I can help you.
