ole smokey
Old Mar 2, 2011 | 11:24 AM
binkks500's Avatar
Default ole smokey
Purchased a 96 disco from my brother with the RH head removed due to a broken intake valve. I replaced the valve, lapped it in, replaced the stem seal but I am burning oil like mad. I will use 2-3 quarts in 500 miles. I did a compression test to see if the rings were bad but got a 162 on the test.All the plugs except #8? look great but I foul that plug with oil quickly. All that said this is my first discovery and I love the machine but don't have any experience with them, any thoughts on the oil consumption?
Old Mar 2, 2011 | 12:47 PM
jafir's Avatar
It is possible to have a stuck oil ring, and still have good compression. (but I don't know if that's common on these trucks... how long did it sit with the head off?) How did that cylinder compare to the others as far as the compression test?
jdhash
Mar 17, 2013 05:05 PM
gulfcoastgorilla
Aug 13, 2012 04:58 PM
RROJ
23
Dec 1, 2010 12:53 AM
