One last lift question
if you use your stock shock with any lift you will severely limit you down travel. your flex will be next to nothing. if you are doing a lift for the looks you shouldn't own a land rover. if you want something that looks good lifted that has no functionality lift a chevy truck with ifs. its pointless to lift ifs trucks. not trying to be rude but if you are lifting a land rover and going to run bigger tires you will lose mpg and stability just for a look. not worth it. lowered shock mounts is like a bandaid. it will fall off and leave you without anything.
again not to be rude or disrespectful but do it right the first time.
