Optima Battery
Optima Battery
Just put a new yellow-top in the Disco today; bought the 34/78 (top and side terminals). My intention was to power the winch from the side terminals and the starter/ everything else on top, but the paperwork that came with it said DO NOT use the side terminals to power a winch. Any idea why not? I just thought it would clean things up a bit.
Where I live, one of the battery stores sells the Odyssey cheaper than sears sells the Diehard Platinum. Only about $5 cheaper, but I will still surprised. I called another battery store, and it was about $100 more than sears.
on
I have run my 9500 HSI Warn winch of the side terminals for nearly 10 years now with no adverse effects. Yes I am aware that most battery companies make the same statement.
If there were to be a concern, it would be if the side terminal and supply enough amps for mutiple pulls with out over heating the winch motor and mine has never over heated and gives a full pull every time I have needed to use it.
Just my 2 cents worth.
Rover Kid
Member Group And Special Buys
12-04-2008 06:52 PM
