Optima Battery
Old Feb 5, 2012 | 08:26 PM
sclarkie's Avatar
Default Optima Battery
Just put a new yellow-top in the Disco today; bought the 34/78 (top and side terminals). My intention was to power the winch from the side terminals and the starter/ everything else on top, but the paperwork that came with it said DO NOT use the side terminals to power a winch. Any idea why not? I just thought it would clean things up a bit.
Old Feb 5, 2012 | 09:13 PM
Well, if they let you run a starter off the side terminals, then re-cable and pull winch from top. Alternator runs most things in the truck, puts some amps back in the battery, tapering down to 5 amps or less. But that starter can pull 300 amps plus for a very short time.
Old Feb 6, 2012 | 04:53 AM
antichrist's Avatar
Yeah, most batteries are like that, the side terminal bus is smaller.
If you'd bought a Sears Diehard Platinum (much better battery made by Enersys), you can power a winch off the side terminals or top post. Both will handle the full load.
Old Feb 6, 2012 | 07:39 AM
jafir's Avatar
Where I live, one of the battery stores sells the Odyssey cheaper than sears sells the Diehard Platinum. Only about $5 cheaper, but I will still surprised. I called another battery store, and it was about $100 more than sears.
Old Feb 6, 2012 | 03:25 PM
DiscoBlanco's Avatar
The Marine battery has marine terminals on top that you can use for your winch.
Old Feb 7, 2012 | 09:10 AM
I have run my 9500 HSI Warn winch of the side terminals for nearly 10 years now with no adverse effects. Yes I am aware that most battery companies make the same statement.
If there were to be a concern, it would be if the side terminal and supply enough amps for mutiple pulls with out over heating the winch motor and mine has never over heated and gives a full pull every time I have needed to use it.
Just my 2 cents worth.
Jordanpryce
Nov 24, 2011 07:32 PM
Rover Kid
Member Group And Special Buys
Dec 4, 2008 06:52 PM
mattrickman
Jul 1, 2008 02:36 PM
Disco2Guy
Apr 29, 2008 08:33 PM
jdelp
Mar 12, 2008 11:02 AM
