Overheating D1
Old Sep 20, 2010 | 01:38 PM
johnkbl's Avatar
Originally Posted by capecodjim
Also,a follow-up. Can the radiator be rodded or is that just as expensive as a new one?
Yes, It can be roded. I did mine in a shop near home, but I do not live in US and I paid $15 bucks for that!!!
You have to take the radiator out, and with a torch, remove the tin in both sides. rod it and then weld it back with a torch and tin. Remember to leak test it with water and a compressor before installing it back.
A good tip, is to put a wide recipient with water in the ground while you are removing the old tin. This way, you can catch the old tin in the water and then, you can melt it and reuse it. :-)
Good Luck!!
Old Sep 20, 2010 | 01:49 PM
DI's have a 3 core radiator and DII's have a 2 core.
The "core" is what cools the coolant, the more cores the more heat it can cool.
If you look at the thickness of the radiator you can see that one more core could be added to a DI radiator.
Takes it out, take it to a radiator shop and have them recore it, should only be $200 or so.
It will come back looking and working just like a new one.
Old Sep 20, 2010 | 05:38 PM
Danny Lee 97 Disco's Avatar
Do you still have your old one? or did it get tossed out?
I have also seen some threads about flushing them yourself and going from there.
If you still have your old one, pull it apart and see what the inside looks like.
We need more people to do what is known as a "Failure Analysis" on removed major assemblies. With the information collected, more of us would know what can be done when we have time to exercise options and good judgement instead of panicing and throwing money at a problem.
If you got removed assemblies laying around, tear into them and take pictures as you go.
Old Sep 21, 2010 | 08:24 AM
okdiscoguy's Avatar
The D1's have small passages that will clog easily. Add to that the common head gasket failures, and you will get clogged radiators. People see a leak and throw in some stop leak. It will clog the radiator. It is very very common to find a D1 with a bad radiator. I need a new one myself. I had it backflushed and a lot of junk came out, but it acts up when it is 110 out.
Old Sep 21, 2010 | 08:33 AM
antichrist's Avatar
If the tanks are still usable on it, a good radiator shop can fix it. Either by rodding or with a recore. Even if you do both (like I did) it's still cheaper than a new one.
IIIRC the radiator shop applied the cost of the rodding ($65) to the cost of the recore since it started leaking within a year.
forbin10
Dec 1, 2005 07:55 PM
Ash A
Nov 15, 2005 01:38 AM
edthediscoman
Oct 5, 2005 01:58 PM
cowgirl1989
Aug 30, 2005 03:31 PM
bakerww
May 24, 2005 09:35 PM
