Overheating Problem Solved
Old 06-15-2012, 10:07 PM
thehun's Avatar
I run 60 % water 40% coolant plus water wetter with 180 thermo...I MIGHT kreep into the 190s with the AC on idling...if I start moving..drops right on or just below 180
Old 06-22-2012, 05:24 PM
Karl Freund's Avatar
3rd Gear
Originally Posted by antichrist
Running that high of a ratio of water:coolant significantly reduces your boiling point compared to recommended ratios.
The boiling point of a 10% mixture is only 10 degrees lower than a 50% mixture, however the better heat transfer properties of the leaner mixture with the WW keeps things nice and frosty.
Did some large hill climbs last weekend at 110 degrees, tomorrow in the desert we are expecting 110-116. Wish me luck!!
ajh
08-25-2015 07:43 AM
Princess
09-06-2011 09:14 PM
rgbeard
08-03-2010 05:46 PM
Atl
04-07-2010 05:39 PM
kma32254
05-28-2009 12:00 AM
Quick Reply: Overheating Problem Solved
