P1316 code after an overheat
Old Aug 24, 2018 | 02:35 PM
Toran's Avatar
This is plug #8
What is my next step?
Thanks
Attached Thumbnails P1316 code after an overheat-sparkplug-8.jpg   P1316 code after an overheat-sparkplug-hole-8.jpg
Old Aug 24, 2018 | 11:08 PM
OverRover's Avatar
WOW that's UGLY! I can't say I've seen a Rover V8 do this before.
Next STEP..... Autopsy.
If you have a scope start by having a look first. Rotate the crank down with a 15/16" socket on the crank pulley bolt to get a better look.
Unfortunately in the end you are still looking at removing the head to have a proper look at any damage and make repairs.
But lets hope for the best.
Good Luck!
Or the Other OPTION.....too soon I know...sorry.
Old Aug 25, 2018 | 02:48 AM
Toran's Avatar
I'll get may hands on a bore scope this weekend and report whats it looks like on the inside.
So this #8 bugger has been the cause of my ticking sound. Seems to always be something.
Thanks
Old Aug 26, 2018 | 09:24 PM
Toran's Avatar
Which direction should I be turning the crankshaft?
Thanks
Old Aug 26, 2018 | 09:57 PM
OverRover's Avatar
Turn the crankshaft to the RIGHT (drivers side), so clockwise.
And if you haven't already, pull the rest of the spark plugs. Also remove the serpentine belt.
The engine will rotate either way, but just far easier with the plugs and belt removed.
Old Aug 26, 2018 | 10:11 PM
Toran's Avatar
Thanks OverRover,
I'll do this in the morning and report the results.
Thanks
Old Aug 26, 2018 | 10:19 PM
OverRover's Avatar
IDK if you posted this or I forgot to ask, but what brand and part number is the boogered spark plug? Just curious to know.
Old Aug 26, 2018 | 10:21 PM
Toran's Avatar
That jacked plug was from a set of Advanced Autos AutoLite plugs.
I am back to the proper Champion plugs now!
Old Aug 26, 2018 | 10:28 PM
OverRover's Avatar
I'll say it for you.....
F U AutoLite!!!!!!!!!!!!!!!!!!!!!!
Old Aug 26, 2018 | 10:33 PM
Toran's Avatar
X2!!!!
