parking lights out only on right side
Do you have an owner's manual? It should have the fuse list in the back. If not get back with us and I will check mine for you but I can't until wed. as I am at work. In addition to checking the fuse and the grounding points I would look closely at the wires themselves. My front passenger side running light/blinker had water getting in somewhere and traveling down the length of the factory shrink tubing and ate away at the blinker assembly. I had to fab in an aftermarket one from NAPA. Good luck.
tibyABv6
12-18-2012 10:09 PM
ruffram
09-01-2011 08:15 PM
