pauls Engine cutting out
Old Nov 23, 2015 | 07:39 AM
Paul Taylor's Avatar
Unhappy pauls Engine cutting out
my 300 series 2.5 engine cuts out, it only happens (usually) within 5 minutes of starting up and might do it a couple of times and after that seems run fine, it sometimes takes a couple of goes at starting up again which can be a bit embarrassing if it happens on a busy junction, any idea's what could be causing this???
Old Nov 23, 2015 | 01:07 PM
TOM R's Avatar
What vehicle is it in, what year
Old Nov 23, 2015 | 07:30 PM
jafir's Avatar
Maybe the lift pump isn't working well and it takes a while of running to get fuel pressure to the injection pump? Or maybe you're getting air in the fuel lines somehow?
I'm no expert on diesels, and not many that use this forum know much about the 300tdi, so you might have better luck at a site in the UK or Australia. How new is the Disco? Some newer versions have something called EDC which complicates things a little.
Old Nov 24, 2015 | 12:34 PM
M3g474rd's Avatar
I know this may sound silly, but how recently have you changed the fuel filter, or spark plugs? Also is it throwing up any codes when doing this, and how does it act on inclines after warm up?
Old Nov 25, 2015 | 06:01 AM
drowssap's Avatar
its a diesel, no plugs or wires
Old Nov 25, 2015 | 12:31 PM
M3g474rd's Avatar
Oops my mistake. I must have missed that.
john1doherty123
May 15, 2008 07:10 PM
A Team
Nov 13, 2007 08:45 AM
ChrisW6
Sep 29, 2007 12:26 PM
westernsun
May 27, 2006 04:24 PM
landrover
May 14, 2006 12:20 PM
