PCV Filter
Old May 8, 2012 | 07:08 PM
Sam95disco's Avatar
Question PCV Filter
Does anyone know why Atlanitc and Pacific British do not carry this part?
Also can this filter be cleaned if so with what?
Thanks.
Old May 8, 2012 | 07:18 PM
Carb cleaner or other solvent, dry with compressed air? see LAND ROVER PARTS - VENT - CRANKCASE V-8
Old May 8, 2012 | 07:29 PM
Sam95disco's Avatar
$146.48 I thought that's what it took to clean it, just wanted to make sure. Thanks Buzz.
Old May 8, 2012 | 07:41 PM
Plenty of solvents on the back aisle of the parts store, or even plain old mineral spirits. You can test a solvent with a clean white rag, and rub the plastic, if the color of plastic comes off on rag that might not be the solvent to use.
Old May 8, 2012 | 07:47 PM
Mineral spirit bath, put it back.
All it is doing is allowing blow by out and not dirt in, in my opinion the dirtier the better.
Old May 8, 2012 | 07:49 PM
Sam95disco's Avatar
I got mineral spirits already.
*in my napoleon dynamite voice* Yessss.
Old May 8, 2012 | 09:21 PM
Do you have any Chap Stick?
Old May 8, 2012 | 09:45 PM
XCELLER8's Avatar
or can you do any cool stunts ?
Old May 8, 2012 | 10:05 PM
Sam95disco's Avatar
But they came out the factory clean how would dirtier be better
Old May 9, 2012 | 04:44 AM
Slightly dirty air filters have additional rough surface area to trap particles. They work even better when slightly soiled. Throw one rock in a stream. Throw a lot more, leaves and grass flowing by begin to get trapped. Do too many, and you have a pretend beaver dam. But if PCV vent is blocked up and your blow by and evaporation of oil can make a pressure to cause some seals to leak that otherwise would not.
