Pinion Angle
Old Apr 4, 2011 | 03:14 PM
errose2002's Avatar
Default Pinion Angle
Ok so I think I have figured out what is wrong
Driveshaft output angle is +2*
Pinion angle is +4.5*
Driveshaft is 10*
So after reading around the internet I have a +6.5* angle total when measured from the passenger side. But the reading says that the angle should be 3* for best performance?
So how do I lower the transmission/xfer case down to 0*?
To reduce the angle on the pinion I can loosen the A arms to a certain point, but then would need to add washers at some point to ensure that I drop the pinion angle to +1*.
Does that make any sense? Or am I just not understanding the whole pinion angle and driveshaft angle deal?
Old Apr 4, 2011 | 05:34 PM
errose2002's Avatar
Ok from the following website
Pirate4x4.Com - Extreme Four Wheel Drive
I came up with the following document to solve my vibration. So does this make any sense?
File Type: pdf
Old Apr 4, 2011 | 07:08 PM
antichrist's Avatar
You don't say if you have a stock D1 propshaft or a DC. That affects what the angles should be.
Drive Shaft tech info
Old Apr 4, 2011 | 10:31 PM
errose2002's Avatar
I have a stock D1 propshaft. I inserted a washer between the bushing and the A arm. I also inserted small washers between the bushing and where the bushing bolts to. It seems to have lowered the pinion angle from 4.5* to 2*.
I think I need to add one more washer between the bushing and where the bushing mounts to. I took it for a test drive and the vibration is less so if I drop the pinion angle as close to 0* as possible then with the axle wrap I should be able to match the operating angle at the top of the drive line, which is 8*.
woza
May 17, 2013 08:02 AM
AuZZZie
Aug 2, 2011 08:51 AM
Camdisco24
Apr 24, 2008 10:33 AM
Camdisco24
Jan 25, 2008 08:37 PM
ajh
Dec 18, 2007 11:27 AM
