Please help! No crank from disco 1.
Hey everyone,
So I just got my newly purchased D1 out of the shop after getting its trans rebuilt. Ran beautifully, drove wonderfully and all was well. Until I shut it off. Now there is no crank whatsoever from the starter-no click, no nothing. like there is no voltage to it. I believe it to be immobilised but the red LED is not staying on when I go to turn the key...however the alarm will still go berserk when you disconnect and reconnect the battery or poke it with a stick to make it go off. Wondering if this is an immobiliser issue or a Park-Neutral Position issue. Part of me still thinks its the immobiliser but I just don't know. The fuel pump is whirring and it will run fine if you jump the terminals on the starter...but I'm afraid to do that to be honest (I don't like electricity) which leads me to think PNP. Is there any way to bypass it or set it properly? This is my only working car so I need it ASAP...and don't have a ton of money to throw at the problem after the trans job. Any help would be much appreciated-I'm totally screwed if she won't run!!!
Not to mention everyone is laughing at me at this point for buying a british car...I'd quite like to shut them up.
Tried the inertia switch already to no avail. doesn't seem like much of a button though, seems hard as a rock.
She is a '99 D1 with a July '98 build date, 4HP22 'box and two button remote. Read about the spider, and the only reason I'm not leaning towards that is it has never cranked for me once. Basically, the shop jumped the starter solenoid off the battery cable with a metal prong of sorts, lots of sparks though and frankly being electrocuted does not sound like my idea of a good time. They did this for me in order to drive it home. It drove absolutely perfectly, no security light or anything of the sort so I thought I may have been in the clear. Not so. When the trans was done and it would only go in reverse there were no such problems firing her up though, so this is new. I'm honestly totally frazzled and frustrated...tried almost everything I've read short of a spider rebuild, remote works absolutely fine (I even replaced the remote battery and have disconnected the car battery 1000 times)...I don't know. I like to think I'm quite good at diagnosing things at the least but this has me stumped. I have no security light whatsoever after unlocking the car and trying to turn the key....which I don't think is right. I know it works though, because when it locks it blinks...
Passenger side kick panel - behind it are relays. K137 is the starter relay. It will have a black with orange wire. Connect that wire to ground. That is what is done by the shifter safety switch.
Left hand side of transmission has a plug for this that must be connected, C323. It will have 5 pins but only four wires, green&yellow, green&brown, black&orange, black&yellow. May have been left un-connected. If this is the problem, then should not need to jumper relay.
