Power Seat Weirdness
There's surprisingly little wrong with my disco lately (whispering that so it won't overhear). One weird thing that I can't wrap my head around tho.... the driver's side power seat only functions with the driver's door open. What is that all about ?? If anyone could point me to a D1 power seat schematic, it would be most appreciated.
From Rave....
Driver Seat
When the Ignition Switch (X134) is in position I or II,
or the left front door is open, the Left Seat Power
Relay (K113) is energised. Battery voltage is then
applied to the Left Front Seat Control Switch (X152)
through the closed relay contacts and the Driver’s
Underseat Fuse Box (P108). Ground is applied to
the Left Front Seat Control Switch (X152) at all
times. The Left Front Seat Control Switch (X152)
controls 4 seat control motors via 8 switches. When
each switch is moved to operate its corresponding
motor, one seat switch applies ground while the
other applies battery voltage to the respective seat
motor. The motor turns to adjust the seat in the
requested direction.
thank you, I haven't been able to find that in the rave. all this time I thought it was messed up... how about that.
CEL came on today, never a dull moment & back in familiar territory once again
this link will take you to the electrical manual.
https://www.cubby.com/pl/LR3+worksho...0Discovery%20I
My right seat don't work at all. pulled plug and checked for power. have power on 1 big lug hole but I don't know what else to check here. can you help me with any info how to make it at least work once to move it back to the read position.
My issue was relay k113. You should check k131 as we'll, as this is the relay for the rt seat. But both seats are fed by k113 when the key is on. Schematic and location is in the thread above
corbin
Feb 12, 2022 08:32 PM
